d15b7 w/ z6 intake many in ex 4 door problems
Old Dec 18, 2011 | 05:47 AM
ef4real's Avatar
Default d15b7 w/ z6 intake many in ex 4 door problems
well finally got my gas mileage build going. It is a d15b7 with a z6 intake and a ebay header. Also i deleted the coolant lines to the iac and the throttle body running a po6 ecu. The car has good power cant find any vacuum leaks but the idle is surging from 700-1200 rpms back and forth already tried another iac still does the same thing. The brake booster has a vacuum leak even when i disconnected that vacuum line the surging still continued. no check engine lights as of yet.
Old Dec 18, 2011 | 05:51 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: d15b7 in ex 4 door problems
1. Bleed your coolant
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-bleed-cooling-system-2341744/
2.Clean and adjust FITV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old Dec 18, 2011 | 07:54 AM
ef4real's Avatar
Default Re: d15b7 w/ z6 intake many in ex 4 door problems
do i need to do a block off plate for the fitv since we deleted the coolant line to it? It looks like the fitv works off the coolant heat.
Old Dec 18, 2011 | 09:48 AM
Technical Hero
Most people do. You can do it with a thin piece of aluminum (some people use from a soda can).
Old Dec 18, 2011 | 11:58 AM
nealnanoHX's Avatar
If you deleted the coolant lines to the IAC then you will have a hunting idle. The IAC works by coolant temp changes.
Old Jun 24, 2012 | 02:00 PM
94coupe-n-it's Avatar
check the tps i had the same proplem on a prelude disconected the tps and it stayed at 1100 rpms
Old Jun 24, 2012 | 02:02 PM
Former User's Avatar
Old thread closed.
lude98SH
Dec 9, 2007 03:05 PM
lude98SH
Oct 29, 2006 03:17 PM
EJ2-Fluffy
34
Apr 25, 2005 06:40 PM
X2BOARD
May 17, 2002 12:57 PM
