d15b7 w/ z6 intake many in ex 4 door problems
well finally got my gas mileage build going. It is a d15b7 with a z6 intake and a ebay header. Also i deleted the coolant lines to the iac and the throttle body running a po6 ecu. The car has good power cant find any vacuum leaks but the idle is surging from 700-1200 rpms back and forth already tried another iac still does the same thing. The brake booster has a vacuum leak even when i disconnected that vacuum line the surging still continued. no check engine lights as of yet.
Re: d15b7 w/ z6 intake many in ex 4 door problems
do i need to do a block off plate for the fitv since we deleted the coolant line to it? It looks like the fitv works off the coolant heat.
EJ2-Fluffy
34
04-25-2005 06:40 PM
