any advanage of running a long wastegate pipe
Old Dec 18, 2011 | 02:36 AM
hoochhenry's Avatar
Default any advanage of running a long wastegate pipe
is there an advantage to running a longer wasetegate pipe to wastegate on a turbo manifold ,thinking of making one up something like this [IMG][/IMG]
Old Dec 18, 2011 | 02:50 AM
cibao2ner's Avatar
Default Re: any advanage of running a long wastegate pipe
boost creep...not something u want...
Old Dec 18, 2011 | 02:51 AM
hoochhenry's Avatar
from what ive heard it helps boost creep
Old Dec 18, 2011 | 07:36 AM
SovXietday's Avatar
Just build it with the proper sized wastegate and give the wastegate a good direction of flow and you will have no issues.
Old Dec 19, 2011 | 04:50 PM
fussman's Avatar
i know that kit. i believe its like that because of space. it was designed to keep
the stock radiator an also to easily remove and install without removing the radiator.
Old Dec 19, 2011 | 05:01 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
I can't see that doing anything good for boost.. seams like creeping will be a issue with it like that
Old Dec 19, 2011 | 05:13 PM
91jdmhatchback's Avatar
^^^ this.
93supercoupe
Aug 23, 2006 06:48 PM
KURUPTinc
Jul 12, 2005 01:04 PM
BodyKits NW
Nov 3, 2003 12:30 PM
Fired Honda
Jul 18, 2003 05:42 AM
