Instead of going with a b18 can I use gsr internals on my b16 to make it a stroker 1.8?
Old Oct 7, 2002 | 09:23 PM
EkTurboHatch's Avatar
Default Instead of going with a b18 can I use gsr internals on my b16 to make it a stroker 1.8?
Any benefit or downfall to this?
Old Oct 7, 2002 | 09:28 PM
simple4012's Avatar
New User
Default Re: Instead of going with a b18 can I use gsr internals on my b16 to make it a stroker 1.8? (EkTurbo
yea the r/s ratio will be decreased from the b16...but then again you will have more torque...
just sleeve the b16 to 84mm and have a super high revving 1.8 liter. Wont put out as much torque as the 87.2 crank but will still run well.
Old Oct 7, 2002 | 09:57 PM
mos's Avatar
mos
The block is shorter than a gsr block so you will need custom rods, which are bux.
Old Oct 7, 2002 | 10:04 PM
The_Head's Avatar
deck height of the B16A is 7 mm shorter than the B18C, the pistons would stick out of the block.
Old Jan 12, 2003 | 07:29 AM
advanracing62's Avatar
could one add a deck plate? or something to that effect? What about LS rods? I've been thinking about doing this for some time now, just to see what will happen.
Old Jan 12, 2003 | 09:58 AM
Mr. Softee's Avatar
it was my understanding b16 rods were stronger than LS rods, and especially stronger than the rod bolts the LS rods use.
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
NOman0608
Mar 16, 2008 06:57 PM
sonicivic
Jun 30, 2007 04:24 PM
civiceg69
Oct 26, 2005 08:07 AM
