info on basic turbo setup, is it correct???
Old Dec 17, 2011 | 01:10 PM
davidjames1983's Avatar
Default info on basic turbo setup, is it correct???
i have a civic coupe year 2000 b16a2 engine, i wanted to tune my engine to 250-300 bhp. the tuner i am taking it to said obviously turbo kit, then he said use the bottom end of a integra typr R with my b16a2 head.
Would this work? and if so how reliable would it be? cause i always drive with my pedal to the floor?
also is there anything else i would need so i dont blow my engine?
Old Dec 17, 2011 | 01:13 PM
EsotericImage's Avatar
Retired Moderator
Default Re: info on basic turbo setup, is it correct???
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Dec 17, 2011 | 01:22 PM
which section is it under cant find it?
Old Dec 17, 2011 | 01:24 PM
TheShodan's Avatar
Moderator
He just sent you to the Frequently Asked Questions section so you can start reading about what you need to get this going. start going through each portion at the bottom of the page.
Old Dec 17, 2011 | 01:31 PM
Dc4LsTeG's Avatar
EK9
Yes a b16a2 head would fit an itr block. No you don't need it to make that power your stock b16a2 block would be fine. As mentioned above read everything in the FAQs BEFORE YOU ASK ANY MORE QUESTIONS. You sound like you don't know much about hondas, so you have a lot of research to do.
Old Dec 17, 2011 | 01:36 PM
crvtectim's Avatar
Haha, I'll spoon feed a little: Op, you can make that power all day by boosting your bone stock B16A2 motor. (ARP hardware advised) Not sure why your tuner would encourage you to purchase the costly Type R bottom end, but that's just silly for your power goals.
Old Dec 17, 2011 | 01:57 PM
was only gettin the itr bottom end because he said the b16a2 stock could only go to 250bhp and that having the stock itr bottom end i could go to 300bhp.
but thanks for your advice you saved me some money
Old Dec 17, 2011 | 03:02 PM
crvtectim's Avatar
If that's his professional opinion, you may want to consider talking with another tuner. A healthy A2 is good to a max of 350whp (roughly 375bhp). Dial that back to your goal of 300bhp with proper tuning, maintain it well with quality fluid changes at the right intervals, and the motor should take a beating for a long time. B-Series POWAAA!
Old Dec 17, 2011 | 04:57 PM
Retired Moderator
http://beesandgoats.com/boostfaq/g2icturbo.html
that is a good read for understanding what your getting yourself into..
Some of it is outdated like FMU,Missing link, etc.. but you can get some knowledge regardless.
Old Dec 18, 2011 | 06:10 AM
that link was great ,was goin to buy a turbo kit, but i think ill research abit more and piece my own kit togeather!! great stuff thanks
Old Dec 18, 2011 | 11:11 AM
nealnanoHX's Avatar
Yeah your B16A2 as it sits will do 300-350whp on boost all day long no problem. Either your "tuner" is trying to make more money off you or he does not know what he is talking about. I would find another tuner. Read the turbo FAQ and do some google searching.
Old Dec 18, 2011 | 02:13 PM
Retired Moderator
theres a few kits sold here in the states that will save you a few pounds over buying individually.
Check Go-Autoworks.com
Old Dec 19, 2011 | 04:21 AM
justed looked on that web site and think im gonna go with the TUNER KIT. looks about right for my power needs! do u know any one who tried this kit before?? how was it?? plus it gives u a chose of differnt turbos i have no ideal which one to pick! can u give any ideal as to which one i should chose.
Old Dec 19, 2011 | 05:34 AM
Retired Moderator
you should keep reading and trying to understand more before buying. Looks like your still new and not quite understanding.
the tuner kit is a great kit, but with the log manifold, it will hurt performance past 6k rpms a it doesnt flow too well up there.
I would do the Race kit with the autoworks spec .55 ar to get to your power goals.
dont forget to get these:
New clutch
better mounts
better brakes
better suspension
Adding 3x more power then the car was designed for requires additional upgrades for your and others safety
Old Dec 19, 2011 | 05:35 AM
nealnanoHX's Avatar
You need to do a lot more reading and research first.
zoopreme
Nov 29, 2011 08:17 PM
cabezon1986
Nov 26, 2008 09:25 PM
delectric
Jul 30, 2005 04:25 AM
Boston_George
Aug 28, 2003 01:49 PM
Bloggsey
May 6, 2002 10:45 AM
