Can this cam still be used on a turbo car? (Pic)
Can this cam still be used on a turbo car? (Damage Pic)
Can this still be used based on the damage in the photo? It's the intake side of a CTR cam. Opinions welcomed but please be specific in your explanation.
Thanks.
Pic of how the cam sits in the head minus the valve cover
Thanks.
Re: Can this cam still be used on a turbo car? (Pic)
can't, cams are cast and it would also require precision machine work to sit flat again.
hmotors sells individual R cams for less than acura new in the box, just buy one and be done with it
Ofcourse you can mix and match cams. Do you have adjustable cams gears to tune them for optimum performance?
How did that cam break by the way?
Yes have Golden Eagle adjustable cam gears....broke while was being pulled out of the head by an amateur....whats funny is the Gsr exhaust cam of the set i already had laying around fell off the shelf in the garage and snapped in half fml....
So now my question is does that chip affect anything when it doesn't touch anything? From what I can tell the distributor O ring does the task of keeping oil from leaking.. I would just hate to let a blemish stop use of perfectly good cams...
cam wasnt dropped it likely was pulled out of the head incorrectly...even the machine shop guy said he sees it all the time people just put them back in and run them...told me the caps hold in cam but he doesnt recommend putting them back in... was just a stupid situation to be in since i already had a set of GSR cams & the Gsr exhaust cam fell off the shelf in the garage and snapped in half...so now im faced with a GSR intake cam & a CTR exhaust cam....
