2000 gsr cluster in a 90 civic dx hatch
If you want to see the difference then this should help...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
Any of them can be made to work.
also have to consider that the vss is in your cluster now, and will not be in the new one, so more custom wiring will be needed to move the vss to the transmission and feed vss signal to the ecu and the cluster.
VSS = Vehicle Speed Sensor (Electrical)
The 4th gens had a Sender in the transmission. There wasn't a VSS of any kind in the cluster. Unless you are referring to the "pulser" on the cluster. The sender was in the transmission and a sensor can be swapped in. The wiring will be easy as the sensor is nothing special. There is a write-up with all the information still on the first page... Regardless, that is a good point to bring up as most people don't realize there is more to it than just switching plugs and clusters.
VSS = Vehicle Speed Sender (Mechanical)
pssmith
Oct 28, 2013 09:14 AM
hondaboy4life
Oct 9, 2006 09:35 AM
