Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow G/C Assembly/Hardware Question
Old Dec 16, 2011 | 08:05 AM
s13hero's Avatar
Default Koni Yellow G/C Assembly/Hardware Question
So I have a set of Konis and G/C coils, I don't think I have all the hardware to assemble them, and can't find them on the koni website because I don't know the name, so I was wondering if someone can help me track down what I need. According to this thread, https://honda-tech.com/forums/suspension-brakes-54/koni-ground-control-install-1212527/ , I am missing a second jam nut, gc spring isolator, and do I need a new top hat bushing? Also, I don't have the brake line bracket, do Konis come with them?
Old Dec 16, 2011 | 04:17 PM
TunerN00b's Avatar
Default Re: Koni Yellow G/C Assembly/Hardware Question
Originally Posted by s13hero
So I have a set of Konis and G/C coils, I don't think I have all the hardware to assemble them, and can't find them on the koni website because I don't know the name, so I was wondering if someone can help me track down what I need. According to this thread, https://honda-tech.com/forums/showthread.php?t=1212527 , I am missing
a second jam nut
Should have come with the shocks. 2 nuts per shock.
gc spring isolator
Not needed if using stock upper shock mounts.
Sdo I need a new top hat bushing?
Not really, but you will need the metal sleeve that comes with the Koni shocks, since the diameter is larger than the stock shock shaft. if it is too difficult to press in the new sleeve, you can open up the rubber a little bit with a file.
No. Either remove the stock one and reuse it, or use zip ties like most of us do.
Old Dec 17, 2011 | 04:15 PM
s13hero's Avatar
I picked up the set used thats why I'm missing hardware. When you say the metal sleeve do you mean the metal sleeve that goes through the bushing?
Old Dec 19, 2011 | 10:03 AM
TunerN00b's Avatar
Yes.
Koni Sports use a thicker shaft than stock shocks, and won't fit through the metal sleeve that the stock shocks used.
Old Dec 20, 2011 | 09:18 AM
s13hero's Avatar
Sorry if I'm being daft, but I use the OEM top hats, just a different sleeve but not a different bushing? Because koni says they don't sell the bushing.
Old Dec 20, 2011 | 09:37 AM
s13hero's Avatar
Ok, so I got the part number, its 70.52.11.644.0, for reference. So I use the OEM bushing with a bigger sleeve?
Old Dec 20, 2011 | 10:23 AM
TunerN00b's Avatar
Correct.
The larger sleeve will fit. Just force it in slowly.
Old Dec 20, 2011 | 01:32 PM
s13hero's Avatar
Do I need the bushing sleeves for all the shocks or just the fronts.
Old Dec 20, 2011 | 01:40 PM
TunerN00b's Avatar
Is this really so difficult to understand?
Old Dec 20, 2011 | 02:23 PM
s13hero's Avatar
The statement isn't difficult to understand, but as written, I wasn't sure if applied to all of the shocks, so I was just asking, as I have only seen assembly instructions for the fronts. Also, I was wondering if anyone got adapters from anywhere else besides Skunk2? GC claims there are no adapters available, but then produce two different sizes of sleeves, one with an adapter built in, so clearly they exist and are made by GC but evidently not sold separately.
bleedblue94
Suspension & Brakes
Sep 18, 2006 07:35 PM
4thgenlude
20
Oct 11, 2004 02:47 PM
natasD5nt
Oct 3, 2003 06:36 AM
jaM3s Bond
Mar 6, 2003 09:57 AM
travis
Aug 19, 2002 01:36 PM
