planning a H22 swap in Accord
I need to know how hard it is to put in a H22 in a 2000 honda accord and what year H22 I need(if it matters) cause I've heard it bolts right in only other thing is an H22 ECU
Also I want to know if H23 blue top is a H23 head, H22 block, Vtech, and if that would bolt right in
and also what else I would need thanks
Im pretty sure its the other way around. The H23 Bluetop uses an H22 head and a 2.3 block. Hmotorsonline has them for $999. Plus they also have OBD2 ECUs for them!
ya u got to mod the driver mount a little bit.
have to rewire the pigtails to the stock f23 fuse box. unless u use a lude fuse box obd2
96 lude shifter and linkage if you don't have stock manual first place.
im doing this swap to and i have researched allot. bout the fuse box thing not to sure yet havent got to try it yet...but when i do i will have a thread for the whole swap...
go to 6thgenaccord.com/forum and there is a whole thread on there for the info!!!
search h22 swap
search h22 swap
Shouldn't have to do anything to the fuse box or anything if you're re-using the F23Ax stock engine harness. Just need to extends some wires, add IABs, and Knock Sensor if the harness does not have a connector for it, etc.
