Old Mar 25, 2015, 09:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
what is better h22 or f20 in 2000 honda accord ex
Old Dec 14, 2011 | 03:56 PM
hondaaccordf23's Avatar
Default what is better h22 or f20 in 2000 honda accord ex
What would be better to put in my 2000 honda accord ex
A H22 or F20
also I drive about 200+ miles a week long distance
Old Dec 14, 2011 | 06:03 PM
Hairnandez's Avatar
Default Re: what is better h22 or f20 in 2000 honda accord ex
As I said earlier in your other thread I think the F20b would be a better choice, but if you can afford an H22, that would also be a great motor.
Old Dec 14, 2011 | 06:16 PM
92civlude's Avatar
Other than the cost,Which is about a hundred dollar difference, why do you think the F20b is better than the H22?
Old Dec 14, 2011 | 06:26 PM
from the other thread i was jw i might sell my other car which is a dodge to get h22 but i wanna try to get engine without selling it and maybe get a integra with selling dodge its just i dont wanna wait a month or so to get engine as im an asst electrician
Old Dec 14, 2011 | 09:09 PM
Hairnandez's Avatar
not sure what your job has to do with it, but just looking on hmotorsonline.com who is very reputable dealer of Honda motors and known for their outstandlingly clean engines, the price for H22 longblock is about 1000-1300 + shipping. where the F20b is 699-849 + shipping where the 699 version is 185hp vs the 849s 200hp. Seems like an obvious choice to me.
You can go the eBay route and get them for 599+shipping for a F20b where the
H22 is 749+shipping.
I have no idea what motors in junkyards in your area go for. We don't have any wrecked preludes in my local salvage yards but as many SOHC accord motors as the eye can see.
Good luck with you choice.
Old Dec 14, 2011 | 09:21 PM
I was saying my job because I don't work everyday so I'm poor right now is what I was saying
Old Dec 15, 2011 | 06:01 AM
92civlude's Avatar
I recently swapped in an F20b in a 98 accord for a customer. The original f23a1 seemed to pull harder in the lower rpm range than the bluetop. For the money he spent, He would have been happier with a high torque H22. So the difference between the f20b and the H22 is $150. Thats not much. And he didnt even mention swapping out the transmission. The F23 trans is geared way too tall for the anemic torque of the F20b. So if the op chooses an F20b, a trans swap for a shorter gearbox is a must. And what if the guy needs a tbelt or engine internals? Does he have to fly to Europe or Japan and find a Honda dealership? That would be a problem. I didnt even mention the language barrier. Would an H23 DOHC VTEC bluetop be a good option?
Old Dec 15, 2011 | 06:02 AM
92civlude's Avatar
A H22 or F20
Have you considered an H23 DOHC VTEC bluetop?
Old Dec 15, 2011 | 07:42 AM
I've considered anything that would make my car drivable but I have friends that tell me to do an H22 Idk much about hondas yet as I just got one but I know a little bit about fixing just to tell you my experience I was thinking H22 because of the torque as there are hills go up
Old Dec 15, 2011 | 10:27 AM
gogydm's Avatar
I agree with your friends. An H23 VTEC would be the best choice if you want torque. If you can't find one, the H22 would be best.
Old Dec 15, 2011 | 08:32 PM
Ocho's Avatar
dang im not the only one swapping an h22 in a 00 accord lol.
so if you have to just worry about the wiring issue.
6thgenaccord.com/forum search h22 swap
Old Dec 15, 2011 | 09:34 PM
nus_dogg's Avatar
Either go H22 or H23A VTEC. No replacement for displacement. I would want to do 2.2L+ as the F20B is a 2.0. But that isn't to say that the F20B won't be enough torque to pull that heavy Accord.
Old Dec 15, 2011 | 10:11 PM
[QUOTE=Ocho;46526986]dang im not the only one swapping an h22 in a 00 accord lol.
yea my F23 is ****ed so going bigger
lol
Old Dec 15, 2011 | 10:12 PM
yea I'm thinking H22 or H23 money is an issue tho I might as well sell dodge and be careful with winter and wash honda so dont rust
Old Dec 15, 2011 | 10:23 PM
nus_dogg's Avatar
I bought my JDM H22A long block for only $900.00 shipped from Japanesestarmotor.com back in '09 and still running strong with the head I built(Skunk2 Pro2 cams + Valvetrain). If you don't want rust, just oil up the underside, rear wheel arc, and where it is commonly known to rust so it won't rust out.
Old Dec 18, 2011 | 02:42 PM
Hairnandez's Avatar
all of that is your opinion. I had an h23, h22 and F23 and the torque is not noticeable between the 3 and I never had an h22 transmission. the so called anemic torque numbers you speak of is minimal. i doubt its even 10lb/ft. H23 and f23 transmissions are perfectly acceptable to use for someone who just needs a new motor and wants something a little better. He's not taking it to the drag strip or the track. Keep in mind he's factoring in cost not maximum peformance.
Old Dec 19, 2011 | 11:56 AM
AFAccord's Avatar
Brice, I think he's correct in referring to the F20b as having anemic torque. That 88mm stroke 2.0 liter would be noticeably weaker in a 3000lb Accord than any F or H 2.2l or 2.3l.
IIRC, the H23 VTEC was considerably more rare and more expensive than an H22. I think a plain jane H22 is the best option for this guy's budget.
Old Dec 19, 2011 | 01:51 PM
Hairnandez's Avatar
in the numbers I've seen posted for F20b, H22 and H23, all around 150-160lb/ft of torque. None of is astronomical and what I would consider anemic. the under 100lb/ft the B16 provides would be. which is found in a 2800lb 99-00 civic. Add a 200lb person and bam, 3000lbs with little to no torque. I understand the gearing of the transmissions, blah blah blah, but the OP is not swapping out his transmission, so regardless either motor will be a suitable replacement to a bad motor. most H23s came in automatic accords and would be a giant hassle to swap from what i have seen.
96accordexproject
Feb 3, 2008 04:06 PM
piropal
Nov 7, 2007 09:27 AM
thing
Feb 9, 2006 06:04 PM
tarlik
Oct 10, 2005 11:18 PM
tarlik
Oct 9, 2005 10:15 AM
