SOHC Intake manifolds
Old Oct 7, 2002 | 08:02 PM
Hyjnx's Avatar
Default SOHC Intake manifolds
I did a search and nothing came up...
I have a SOHC EX vtec blah blah blah...and i was wondering what manifolds and throttle bodies would work for my engine ?
Old Oct 7, 2002 | 08:09 PM
idreamsi's Avatar
Default Re: SOHC Intake manifolds (Hyjnx)
all b and d series throttle bodies and if you have the z6 then you can put a y8 intake mani on it and would be a little better do to the y8 having shorter/fatter runners I do believe someone correct me if I am wrong. But you won't really get the full benefit from swapping these parts unless you have everything port matched and so on.
Old Oct 7, 2002 | 10:42 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: SOHC Intake manifolds (idreamsi)
that would be correct...opt for an LS TB- cheaper and GSR TB will require some fitment issues. Or a B16 TB. And yes, get a Y8 intake manifold. Do some head work with a thinner head gasket, and you'll see some good improvements over stock!
Old Oct 7, 2002 | 10:43 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: SOHC Intake manifolds (Emerica)
actually, also check out Spade's thread on "D series upgrades"- you'll learn a lot.
Old Oct 8, 2002 | 03:53 AM
idreamsi's Avatar
Yea check that out I completly forgot how dare I it has to be one of the best threads I have seen.
Old Oct 8, 2002 | 04:03 AM
kevcp's Avatar
here is the link https://honda-tech.com/zerothread?id=261161
enjoy...
Old Oct 8, 2002 | 07:02 AM
gshockbreaker's Avatar
Default Re: SOHC Intake manifolds (kevcp)
I have a 2001 Civic EX, also SOHC. The new civics have plastic intake manifolds anyway, I want to nos my engine, but I need to replace my intake manifold b/c I know that this guy blew his cheap plastic intake manifold. Can I also replace it with any D or B series manifold?
Old Oct 8, 2002 | 07:07 AM
Spade's Avatar
Default Re: SOHC Intake manifolds (gshockbreaker)
I haven't had my hands on the D17's yet. Judging honda though, the older D series Intake Manifolds should fit right on.
BTW, B series manifolds don't fit on the D series engines just the trottle bodies.
Old Oct 8, 2002 | 07:21 AM
Default Re: SOHC Intake manifolds (Spade)
Will the inverted throttle body be a factor when replacing the intake manifold?
[Modified by gshockbreaker, 11:23 AM 10/8/2002]
Wes90civic
11
Feb 2, 2018 06:52 AM
jlacoy82
Dec 18, 2004 10:38 PM
RSXrunsit
Jan 19, 2004 08:14 PM
Shadow Templar
Dec 22, 2003 08:52 PM
spun Vtec
May 31, 2003 08:07 AM
