1996 civic died while driving!!! need help!!!
Old Dec 13, 2011 | 05:58 PM
89hatcher's Avatar
Default 1996 civic died while driving!!! need help!!!
ok so i was driving into work this morning and was cruising at about 60mph and then car all of a suddend died, so i pulled over to the shoulder lane. I tried to start the car, car cranks but not getting any spark, main relay clicks on when its on the on postition and can hear the fuel pump priming. distributor and battery is 6 months old. no check engine codes. ignition has also been replace within 1 year. any help would be appreciated. trying to fix my daily. thanks in advance.
Old Dec 13, 2011 | 06:11 PM
sfar785's Avatar
Default Re: 1996 civic died while driving!!! need help!!!
always start with your dizzy, it might be 6 months old but that doesn't mean it didnt take a **** on you.
Old Dec 13, 2011 | 07:17 PM
furious94ls's Avatar
Is the dizzy re-built, aftermarket, or used honda part?
Old Dec 13, 2011 | 10:57 PM
tobster's Avatar
new distributor should be under warranty
Old Dec 13, 2011 | 11:46 PM
LoLoCivic's Avatar
sounds liek your dizzy since you said no spark
Old Dec 14, 2011 | 12:30 AM
89hatcher's Avatar
I believe its a aftermarket dizzy. Gonna try replacing the dizzy with a working one. I lost the receipt for the dizzy so I can't replace it with a new one. Could it be the ignition switch also?
Old Dec 14, 2011 | 08:04 PM
89hatcher's Avatar
Got the car to start. Changed the ICM with one from my old working dizzy and the car fired right up.
Hatchd Egg
Oct 18, 2009 04:17 PM
bmxmacdaddy
14
Jan 8, 2009 08:04 PM
filet611
May 27, 2006 08:40 AM
xkagax
13
Feb 22, 2006 05:47 AM
