ls/vtec oil capacity
Old Dec 13, 2011 | 12:58 PM
alperx's Avatar
Default ls/vtec oil capacity
I'm trying to gather everything to make it ready for tuning..
does the oil capacity differ from the stock engine if I have mocal oil cooling kit and filter relocation kit & T3/T4 turbo are installed ?
do you think I can use the filter relocation with the Mocal oil sandwich with thermostat at the same time ?
can using reloction kit cause any pressure or any other problems in any way ?
Old Dec 13, 2011 | 01:32 PM
Turbo-LS's Avatar
Default Re: ls/vtec oil capacity
If you added an oil cooler itas going to hold more oil. Put in 4 quarts and start it and let it run, shut it down and check oil level, it will take more im sure, just fill to the full line and your ready to go. pressure drop will be minimal if any, keeping oil cool is a good idea even for a few PSI less pressure
Old Dec 13, 2011 | 01:57 PM
alperx's Avatar
well, ok thanks, is pressure drop related to oil cooler or relocation ?
Old Dec 13, 2011 | 02:01 PM
boostedEF91's Avatar
There really shouldnt be any pressure drop. If you notice a big drop then there is something else wrong.
Old Dec 13, 2011 | 02:09 PM
Turbo-LS's Avatar
it will be minimal if at all. 1-3 psi max anytign else i would assum there is a problem
Old Dec 14, 2011 | 12:31 PM
sp00led's Avatar
I don't notice any pressure drop with my oil cooler but I swear it does take a second longer to build pressure on cold starts.
Old Dec 14, 2011 | 12:41 PM
TheShodan's Avatar
Moderator
Its going to based upon how the relocation is for the oil cooler. I found keeping the stock location of the filter, smaller , shorter lines, no oil filter relocation, would be better in the long run. I've had several oil coolers. Hondas take a little while to get that oil pressure up. Just keep a good Eye on it.
Old Dec 14, 2011 | 01:33 PM
alperx's Avatar
I think I'll just use the Mocal oil thermostat sandwich with the oil cooler radiator with simple 2 lines in&out. So it would keep things simpler.
While cranking, I think I build the oil pressure. My cranking takes a bit longer than normal since I have the older version of Neptune RTP which prevents the fuel pump to run just before cranking.
Tachi
May 11, 2015 06:16 AM
Elevorett
10
Jan 2, 2010 06:23 PM
ALL IMPORT
Jul 23, 2006 02:43 PM
Black R
Jun 27, 2004 05:54 PM
hondapwr
Mar 11, 2004 02:43 PM
