91 ef converted to obd1, need resistor box again lol
Old Dec 11, 2011 | 09:53 PM
accordin 2 me's Avatar
Default 91 ef converted to obd1, need resistor box again lol
how do i put it back in, i bought a set of injectors from crvtectim and there low impedance so they require that i put the injector box back in but i dont even know where to start. its a 91LX converted to mpfi and obd1. do i just go to that green injector plug where all of the wires are connected and put the resistor box there? i can unplug the part where all of the wires are connected easily.
Old Dec 11, 2011 | 10:51 PM
crx_si-r's Avatar
Default Re: 91 ef converted to obd1, need resistor box again lol
pictures of what you did to your harness will be somewhat helpfull
Old Dec 12, 2011 | 03:55 AM
Spug's Avatar
The question I have for you is:
If your injector resistor box was already gone, why the heck did you buy those injectors?
Old Dec 12, 2011 | 04:52 AM
KINGVEM^^ED6's Avatar
Id buy some obd1 injectors and sell the obd0 ones
Old Dec 12, 2011 | 05:20 AM
I have obd1 injectors in the car. I bought rc310s and i didnt know they were low impedance when i bought them. And i got them for 40 bucks so i cant complain. Ill take a pic after my finals
Old Dec 12, 2011 | 01:23 PM
crex23's Avatar
I bought this off Ebay since I'm using obd1 injectors with a obd0 ecu. That way if I ever need to swap the injectors to obd0 ones, I just unplug this and plug in a resistor box and I'm good to go.
http://www.ebay.com/itm/CRX-Prelude-...item2c6158d137
Old Dec 12, 2011 | 02:13 PM
Im just gonna try what i said tomorrow to see if it works. The resistor box will cause the injectors to get 5.5v instead of 12v needed by high impedance injectors
Old Dec 12, 2011 | 03:04 PM
4drEF's Avatar
Keyboard Humorist
Yes.
I am reading your post 2 ways though.
Do you have an 'injector resistor box delete' plug on your harness?
If so, just pull it out and plug in the resistor box.
Done.
If you don't have the plug, then ...
You have 4 smaller wires from the engine harness that connect to one wire that runs into the cabin.
Each of the smaller wires go to one injector.
The one wire goes to the main relay for power.
So just separate the 4 wires and hook them to the plug for the resistor box.
In this pic you see 4 black wires - they are the the 4 wires.
All connections provide the same resistance so it won't really matter to which spot you connect.
Then hook up one wire to the box where the red wire in the pic is and you are done.
You can even make your own box... but the OEM box will dissipate heat better since the housing is a large heat sink.
http://www.srtforums.com/forums/f75/...ectors-530477/
Old Dec 12, 2011 | 05:05 PM
thx 4dref, yea i assumed the way i thought it should be done was confirmed but heres a night pic of my filthy bay for referance
left circle is a "homemade" delete, top right circle is the oem wiring for the injectors that went to thee resistor box, and the bottom right circle is the plug for the accord resistor box that i got from the junkyard. the plug is not plug and play but if i use my original resistor boxes "delete" plug then it will be. the colors are not the same but there is one wire that is different just like on our cars so it should work
Randysi
Apr 4, 2012 10:17 AM
surkitroller
Dec 29, 2009 12:58 PM
beansandrice
33
Sep 8, 2009 04:18 PM
mr. Grind
Aug 15, 2004 12:13 PM
kur0ryu
Apr 26, 2004 05:05 PM
