Which turbo clear the block with SpoolinPerformance Log mani?
Old Dec 11, 2011 | 11:08 AM
codenamezero's Avatar
Default Which turbo clear the block with SpoolinPerformance Log mani?
Hello, for those who are using the log style manifold from SpoolinPerformance, could you list the turbo that you used and have no issues of clearing the block? I want to see what options i have with no extra modification.
Motor is a b18b, bone stock, HP goal 250whp.
Old Dec 11, 2011 | 11:28 AM
TheShodan's Avatar
Moderator
Default Re: Which turbo clear the block with SpoolinPerformance Log mani?
You're talking about the schedule 10 log manifold and nothing cast correct?
Not
The turbo used is irrelevant. On any of his manifolds to fit, the best ones to use have a T04b Compressor cover and a T31 4 bolt turbine housing. (This includes the GT3255b, Silver surfer, Wolverine, or any T04B housed/compressor cover) Though the standard T04E compressor cover for the 50,60,60-1, and 61mm (SC61 or similar) can fit, (This includes anything in the Precision camp w/ cast or billet compressor wheels) you'll definitely need to do some block grinding.
For example: Californiadad's Silver surfer build does not require any block grinding.
Old Dec 11, 2011 | 02:37 PM
Mr.Spec's Avatar
You'll need a To4b housing to avoid notching . Otherwise you're not making any compromises to fit the ac and not block notching
Old Dec 11, 2011 | 04:01 PM
Yes, i got the "schedule 10 log manifold" that is AC/PS compatible. And crap, from what Mr.Spec just posted, i guess my choice would now be quite limited...? (AC/PS is a must, i'd like to retain as many stock component as possible)
Would the SC50 fits without grinding?
Old Dec 11, 2011 | 08:07 PM
TheShodan's Avatar
Moderator
Nope. the SC50 (as with any Precision turbo) uses at minimum a T04E compressor cover. You'll be grinding away..
Old Dec 12, 2011 | 09:36 AM
nealnanoHX's Avatar
The GT3255B theshodan suggested is a great turbo to use, you are not really that limited.
Old Dec 12, 2011 | 11:53 AM
BigMike0147's Avatar
It just might be harder to find a turbo that uses a B cover if you don't have it custom made. Typically I see a lot more E and S covers than I do B covers on the mainstream market.
Old Dec 12, 2011 | 05:50 PM
nealnanoHX's Avatar
^ Yep that is because the B is a older style. However the shodan has proven these to be very effective on the correct setup. You just need to know where to find them and who to ask. I called Turbos Direct for a quote the Garrett GT3255B and they could not find it, I will be ordering one from theshodan once I have saved up of one.
Old Dec 13, 2011 | 04:46 AM
fcluddington's Avatar
OP how much whp are you trying get? is this a sleeved block and a daily driver?
Old Dec 13, 2011 | 04:53 AM
Yeah, I know. Just got my GT3251B from him. Looking forward to getting car tuned soon
Old Dec 13, 2011 | 06:37 AM
nealnanoHX's Avatar
^^^ let me know how much power you make with that turbo. I will be getting one soon I hope.
Old Dec 14, 2011 | 12:12 AM
Mr.Spec's Avatar
get off your *** and get a right angle grinder and notch the block.
not sure what people are thinking anymore when they dont make the necessary requirements to fit an AC compatible manifold/turbo setup
Old Dec 14, 2011 | 06:42 AM
TheShodan's Avatar
Moderator
Such as? Please give an example of this statement, if you don't mind.
Old Dec 17, 2011 | 12:11 PM
Sorry for the late reply. goal is easy to archive, 250-300whp, aiming for 250 pretty much. Everything stock, must keep AC/PS, which is why i chose the log style manifold (cheaper than ramhorn and works for what i need).
Man, i was thinking of grabbing this cheap turbo for my setup... but as the other stated, gotta skip the t04E...
It will be my summer DD, i do have a Honda Fit, so not worry about downtime hehe...
Old Dec 17, 2011 | 01:22 PM
TheShodan's Avatar
Moderator
Even if you did get that piece of ****, you'd STILL be grinding the block, as that is a T04E compressor cover. So now you'd have to grind the block for a spinning door stop.. that's double the trouble over nothing.
Old Dec 17, 2011 | 01:30 PM
crvtectim's Avatar
Lol @ spinning door stop!
Old Dec 17, 2011 | 01:31 PM
Silva Bullit DC4's Avatar
With a Precision T3 4 bolt turbine housing (.63 a/r), and standard T04E comp. housing, I didn't have to notch my block at all with mine years ago. The turbo was an SC-3431E. Was a tight fit, much tighter than my B housing Borg Warner, but it cleared.
I don't know if Phil is still making them like his first design, I purchased mine in 2007. And of course, all manifolds are not gonna be precisely the same, fitment wise.
Old Dec 17, 2011 | 01:34 PM
lol that is why I said ' was' going to get, until I saw I need to grind the block... hey shodan, got a suggestion turbo that is small enough to push about 30lbs/min? and that I don't need to grind my block? :-)
Old Dec 17, 2011 | 02:15 PM
Thanks Silva Bullit DC4, i will try to look up the compressor map and plot some stuff on that SC-3431E.
Old Dec 17, 2011 | 03:19 PM
racebum's Avatar
mentioning of cast manifolds and E cases, i just test fit the 5431e on an inline pro cast iron manifold and it just BARELY fits without grinding. we're talking about 1/4" of space between the black on turbo....maybe. 3/8"
Old Dec 17, 2011 | 08:09 PM
TheShodan's Avatar
Moderator
an sc3431 is a 57 trim t04E turbocharger. no different than a Garrett physically
Old Dec 17, 2011 | 08:22 PM
TheShodan's Avatar
Moderator
T3 super 60 is over 35lbs/min but that ake 300whp at maximum. never choose a turbo based on its maximum output.
GT3251b is 48lbs/min and is in t04B config shown below, but this one had additional coatings on it
DELshaneSOL
Mar 12, 2012 12:23 PM
Fc_v8
Sep 21, 2010 01:01 PM
BoostedEgHatchFl
Feb 14, 2010 07:43 AM
billy18c5
Dec 11, 2007 06:57 PM
BLKCRX
May 4, 2003 04:44 PM
