6266 and 6766 Dyno numbers and Spool?
Old Dec 9, 2011 | 01:36 PM
Steeve_Civic's Avatar
Default 6266 and 6766 Dyno numbers and Spool?
Do you have some Dyno sheet with 6266 and 6766?
What are the spool difference with same AR? 1000rpm?
Old Dec 9, 2011 | 04:39 PM
TheShodan's Avatar
Moderator
Default Re: 6266 and 6766 Dyno numbers and Spool?
The XX66 turbine wheel is a bit too new for anyone to have such a comparison, for a given engine. Engine size, rpm, A/R all play a factor.
Give until next Spring here in the U.S... then you'll find some results to compare to. Suffice it to say, its for those that want over 500whp on a lower amount of boost for the 6766 and is for drag racing only, really.. not too much street use.
Old Dec 12, 2011 | 06:47 PM
RoadconeTuning's Avatar
I've yet to see any numbers from a 6766... I figured we'd see something by now
Old Dec 12, 2011 | 07:01 PM
sanman000719's Avatar
give me a month ill post some
Old Dec 12, 2011 | 08:25 PM
Casey's Avatar
search google. i found a 6766 vs 6765 on evo and supra. the 66 wheel is making 80+ whp more.
on the supra, they compared a 6266 to a 6765 as well. the 6266 had a fatter powerband and made more power up top
Old Dec 12, 2011 | 09:21 PM
TheShodan's Avatar
Moderator
That's not really because of the exhaust wheel. There's a bit more to it, including but not limited to the amount of boost pressure used per range. Its hard to do "back to back" to jump to such a conclusion.
Just be patient, people, real results will come soon.
Old Dec 13, 2011 | 11:46 AM
i found a few shops that had done dyno comparisons... generally the new turbos made 30-50hp more once spooled at the same level of boost... STM had comparisons using an EVO VIII
darksolguy
Dec 3, 2007 04:05 AM
94vtirozguy
Jul 25, 2006 02:03 AM
Norcalstoppy
Sep 28, 2005 06:48 AM
hooptie157
Honda S2000
Sep 17, 2002 12:51 PM
