idea on how to make these
Old Dec 7, 2011 | 01:49 PM
hoochhenry's Avatar
Default idea on how to make these
looking to make some of these from mild steel so i can run my tubing stright up from the collector mybe a bigger tubing can be used not to sure .[IMG][/IMG]looking to do a 4/1
Old Dec 7, 2011 | 10:27 PM
Golfball's Avatar
Default Re: idea on how to make these
exact same process as making any kind of collector....
clamp it in a jig cut an angle... rotate... repeat. weld together....
sorry its 130 am and im beat, someone will explain better im sure.
Old Dec 8, 2011 | 02:45 AM
Boosted_B_Series's Avatar
Those look alot easier than turbo collectors.
If your going the thinwall rout, just buy a stamped collector, looks almost identical to what you have pictured, just no seams.
Old Dec 15, 2011 | 11:50 AM
RickyLee53's Avatar
Why not just use a merg collector with a shallow angle.
Old Dec 15, 2011 | 01:36 PM
hoochhenry's Avatar
any idea were i can bu them ricky
Old Dec 21, 2011 | 04:54 PM
TunerN00b's Avatar
http://www.burnsstainless.com/mergecollectors.aspx
Old Dec 22, 2011 | 05:51 PM
intense4thgen's Avatar
you could draw them flat like in auto-cad and then get them formed as well
Old Dec 22, 2011 | 10:26 PM
Tony the Tiger's Avatar
They don't perform anywhere near a true merge collector.
Many cheap headers for common V8 applications use these formed or stamped collectors. Compare to true merge collectors, there is no comparison.
Snailor Built
Welding / Fabrication
Mar 12, 2015 12:41 PM
powerneedy
Oct 23, 2012 07:53 PM
mike626t
May 25, 2009 07:48 PM
Jonathan_ED3
Audio / Security / Video
Dec 10, 2004 08:02 AM
kb58
Oct 29, 2004 10:27 AM
