b18c exhaust
hey all new to the forum and have a quick question. just replaced my swapped b18c with another lower km b18c when i bought the car it had the whole exhaust already done (header 4-2-1, highflow cat and big fart can out the end. now when i got the car cert&e-tested my mechanic said i should consider going with the type r stock muffler, including saying that my car is super loud and super heat lol. its got a mean sound right now but it is overly loud. my question is this, with the big can am i losing back pressure? and will the type r muffler correct it and give me more hp? aswell how much quieter will the car be? thanks
straight through mufflers do not restrict flow. If you did all that work to the exhaust, what size pipe did you use? it would be a lot quieter with the stock muffler on, you wont loose too many horses. In my opinion, having the stock muffler is wayyy better than having a fart can. straight pipe all the way
you want a little backpressure for torque if its NA.Turbo is another story.
but lose the fartcan and find a real muffler. OE is fine, or magnaflow, or ____
thanks guys, that being said perhaps i should just go with a different straight through muffler? like a magnaflow / thrush because the can thats on there i think is no name crap i didnt do the exhaust just the swap on the motor, plus it looks like s***.what has everyone else been using? thats worked for them?
3" is beneficial on all b-series h-series, and k-series, period. It is probably true for d-series too. You will gain power everywhere on the power band.
And about 40 decibels.
Good info I also have a b18c swap in my gsr I'm running 2 1/2" pipe stock cat apexi ws2 exhaust but I think its not load enough.....if I put a test pipe on you think it'll make a difference???
