Sand In Valve Cover..HELP!
Old Dec 6, 2011 | 12:27 PM
Steezer's Avatar
Default Sand In Valve Cover..HELP!
So i just got my valve cover back from being sand blasted at a powder coating shop. And when i got it back a shitload of sand fell out when i picked it up! I dont think the shop masked off any of the holes on the cover! Should i just wash it out with water, put it in my dishwasher, use an air compressor and blow it out, use a solvent to get off the grime which the sand sticks to or am i screwed and I should just buy a new one? Any advice???
Old Dec 6, 2011 | 01:14 PM
riceburner700's Avatar
Default Re: Sand In Valve Cover..HELP!
I would try and compressor water through it for a while
Old Dec 6, 2011 | 01:35 PM
Steezer's Avatar
yea like a pressure washer?
Old Dec 6, 2011 | 02:08 PM
Steezer's Avatar
bump
Old Dec 6, 2011 | 02:11 PM
carbon fiber coupe's Avatar
just blow it out with an air hose, or throw it on a parts washer
Old Dec 6, 2011 | 08:34 PM
joeshmo's Avatar
Pressure wash then blow out with 100psi.
Old Dec 8, 2011 | 10:34 AM
k-series's Avatar
Blow it out with air first. The water will only make the media stick to the insides of the cover. Since the baffles on MOST honda covers are rivetted, you need to be VERY careful. After you pushed through some decent air THEN give it a good rinse with a hose, tilting the cover to allow for water to flow everywhere and move the media around and out of the cover.
This is pretty bad IMO. Be VERY careful.
Steve
Old Dec 28, 2011 | 02:49 PM
turbo-2nr's Avatar
thats how every cover iv ever goten done comes back, just drill the rivets out, remove, baffel, then rivet or drill and tap the wholes and bolt it back in
Old Dec 28, 2011 | 03:02 PM
Steezer's Avatar
problem solved. i just cleaned it ALOT with brakecleaner, soap, water hose and air blasted it. i also used a wire brush to get into creases. Hope this helps people out.
Old Dec 29, 2011 | 05:34 AM
k-series's Avatar
That's awful. Your blaster needs to mask/plug them or you should prior to sending them out. It's gotta be less work to mask than it is to drill/re-tap.
Steve
Steezer
Dec 6, 2011 05:24 PM
dannyly17
Jan 14, 2011 08:20 AM
b20beast83
Feb 5, 2009 06:33 PM
Ivan
Jun 27, 2003 04:37 AM
citanest
Jan 7, 2002 06:46 PM
