How to tap valve cover
Old Feb 4, 2009 | 01:21 PM
b20beast83's Avatar
Default How to tap valve cover
How are you guys tapping your valve cover at the front?
There is a baffel plate at the front.
Do you drill thru? if yes how do you clean everything out after
Old Feb 4, 2009 | 01:25 PM
B R Fittings's Avatar
Default Re: How to tap valve cover
Use a stepped drilled bit so you don't drill through the baffle, also known as a unibit. When your done blow out the valve cover with compressed air. To get the rest of the aluminum shavings out fill up your bath tub with water and drop the valve cover in. That should get the rest of the shavings out.
Old Feb 4, 2009 | 07:09 PM
kranky81's Avatar
nice! now i know! and knowin is half the battle
Old Feb 4, 2009 | 07:25 PM
b20beast83's Avatar
Great! Thanks alot
Old Feb 4, 2009 | 07:50 PM
HiProfile's Avatar
They also make a sort of collar with a setscrew so you drill to a set depth. The baffel shouldn't be cut otherwise the valvetrain will eject oil into your lines.
Old Feb 5, 2009 | 02:04 AM
IN VTEC's Avatar
I cut a 1/4" drill bit down and used the appropriate sized hole saw.
Old Feb 5, 2009 | 01:12 PM
single cam fan's Avatar
I just took mine to tony at T1
Old Feb 5, 2009 | 03:21 PM
philafelman's Avatar
you can also wrap a drillbit with tape as well to limit the depth.
Old Feb 5, 2009 | 06:33 PM
90blackcrx's Avatar
Blah, he probably didn't even drill holes in the valve cover.
b20beast83
Feb 4, 2009 01:23 PM
FLCivic
Jul 30, 2002 10:46 AM
