CRX sunroof problem (no power/bad motor?)
I have tried 2 switches so far and the fuse seems fine. When I press the button I hear nothing nor anything happens. Do I have a bad motor? Anyone else diagnos this? Thanks.
use a 12v (or a little lower if you dont have 12v) battery off a drill, unplug the leads to the motor and using spare wire tap the battery against the plug for the motor.... if it moves, its good and you have problems elsewhere
JeanGeslin
Jan 15, 2019 03:13 PM
