2002 rsx will not crank..help!!!
so i had CEL which was p0661...i cleared it with my scan tool and everything was fine...the next morning i go to start my car and it wont start!!!...i hear the fuel pump relay clicking and the fuel priming but it wont crank....i tried jumping battery and its still not doing anything...any ideas?
By crank im assuming you mean that you cant get it to turn over. Try taking a really long screw driver and arcing the starter directly. Also check the the grounds and the power to the starter and make sure they didnt come loose. If all this checks out, and you cant get it to turn over even when you arc it with a screwdriver then its time to get a new starter.
Sorry I have no computer ATM mine crashed.
When you try to turn it over do you hear anything? Can you hear the starter turning? Is the engine trying to turn over or just nothing?
***break**
what is the easiest way to remove a starter from a 2002 rsx base model?
thanks for the advise guys...it was the starter...its actually not that bad to replace..this is my first k series motor and i thought it was gonna be as hard as taking off a b series manifold...
Acuranoob
Nov 30, 2014 07:34 PM
crxb16a90
Oct 3, 2011 12:42 PM
junya16
Mar 1, 2003 07:30 PM
