what size 16" tire will fit my ef hatch?
Old Dec 3, 2011 | 05:22 AM
zapzach's Avatar
Default what size 16" tire will fit my ef hatch?
i have a 1990 (stock height) civic hatch with 170/70-13's.
i have a set of 16" rims with no tires.
what tires should i use? ..that will still fit with no rubbing.
the more sidewall the better.. can i go 205/50-16? or do i have to keep it 45 and below?
Old Dec 3, 2011 | 08:20 AM
toyomatt84's Avatar
Sanji
Default Re: what size 16" tire will fit my ef hatch?
205/50/16's would be extremely oversized for the chassis. The closest you could get would be a 205/40/16, and even that is slightly oversized.
Old Dec 3, 2011 | 09:11 AM
zapzach's Avatar
thanks i figured i would need low profiles.
what about 195/50/16? would that work?
Old Dec 3, 2011 | 09:23 AM
toyomatt84's Avatar
Sanji
The difference between the 195/50/16 and 205/50/16 tires is not nearly enough to make the tires fit your car properly.
Factory tire diameter - 22.09 inches
205/50/16 diameter - 24.07 inches
195/50/16 diameter - 23.67 inches
205/40/16 diameter - 22.45 inches
So, in summary, no they will not safely work.
Old Dec 4, 2011 | 04:39 AM
zapzach's Avatar
that's awesome insight man, thanks a lot!
you saved my ***.
Old Dec 6, 2011 | 03:40 PM
doc@tirerack's Avatar
We recommend 195/45R16 and 205/40R16
Acid X
Feb 7, 2009 12:55 PM
JSJ EG6
Mar 23, 2006 09:24 PM
highrpmek
Jun 30, 2003 11:56 AM
Phase2
Apr 30, 2003 05:49 PM
TurBoXBirD16
Feb 6, 2002 06:17 AM
