TireSize?
TireSize?
I have a neuspeed sport springs and tokico struts
i am going to put on a 16" rims, i am just wondering what size of the tires I should put?
should i use 16/45/205? or 16/50/205??
and also what are the best tire for cornering and start up??
thanks alot !!
thanks alot !!
Re: TireSize? (xbird)
Hmm.......use the 205/45R16 tire. In that size I like the Pirelli P7000, Kumho Ecsta Supra 712, Yoko A520, Dunlop SP9000, and Pirelli P Zero. If you don't care much about wet traction then get the A520 or P Zero. If wet traction matters, then go with one of the others.
if ur going to drop ur car more than 2ins. id consider the 205/40/16..as for tires? id consider drivers skill first and not allow a tire to compensate u for lack of it..learn to take what u have to the limit and go from their
If you will be using Tokico "blues" then do not get 205/50/16 tires. The shocks are ok, but not too strong. With the taller tires, you may rub in certain situations. I would stay with 205/45/16 or 205/40/16 if it's a G5 Civic.
EX-T
03-19-2010 10:31 PM
CLICC916
02-13-2002 01:38 PM
