How many max boost pump gas 95
Old Dec 1, 2011 | 05:33 AM
Ammory Hasanain's Avatar
Default who much can i boost
Hello My friends
I want to who much can i boost my B16a engine with pump gas 95
I hope you reply
Old Dec 1, 2011 | 06:52 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: How many max boost pump gas 95
I hit my max boost everyday and I run 93 octane.
Old Dec 1, 2011 | 07:07 AM
4drEF's Avatar
Keyboard Humorist
Old Dec 1, 2011 | 07:35 AM
How the boost 18 or 15 psi
Old Dec 1, 2011 | 07:38 AM
Originally Posted by 4drEF
What ?
Old Dec 1, 2011 | 08:10 AM
4drEF's Avatar
Keyboard Humorist
Again.
Old Dec 1, 2011 | 08:12 AM
4drEF's Avatar
Keyboard Humorist
First post you didn't say anything to even give a hint for what 'max boost' on YOUR car is.
Second post you said 'psi' which is totally meaningless without knowing what turbo.
Why are you even asking?
Just have your car tuned with 95 octane in the tank.
Old Dec 1, 2011 | 08:14 AM
crvtectim's Avatar
Lol
Some dude: "How much boost do you run?"
Me: "All of it!"
Old Dec 1, 2011 | 04:56 PM
Question is not clear
ok
Old Dec 1, 2011 | 05:08 PM
I want to know how many of the boost (psi) which I get to 400 hp
I used 95 octane
This is my car parts
civic Ef
b16 bored 81.5mm
Darton MID Wet Sleeves
wiesco 9:1
Eagle rode H
ARP Head studs
Acl race bearings
Supertech springs and retainers
Stock valves
Cometic Headgasket
Skunk 2 70mm throttle body
Gsr cams
OEM cam gears
Genuine OEM Honda Type R Water and Oil Pump
all gaskets and seals are OEM honda and are new
Precision Turbo 5557 / T3 / 0.63
GO-AUTOWORKS Mini Ram Manifold
GO-AUTOWORKS 88-91 Civic/CRX Custom Race Kits
GO-AUTOWORKS Catch Aluminum S-Can B Series Combo
GO-AUTOWORKS Turbo Downpipes
GO-AUTOWORKS Medium Intercooler
Precision 44mm wastegate
HKS SQQV blow of valve
Injector Dynamics 1000cc
walbro 255
COMPETITION STAGE 4 b SERIES CLUTCH KIT
Competition Flywheel
Axles Stage 2
HONDATA 4 bar map sensor
Neptune RTP & TunerView
Electronic Boost Solenoid
TunerView II LCD Large Dash Kit
k-tuned Traction bar kit
I do not want to use racing fuel
I hope you reply
Old Dec 1, 2011 | 05:49 PM
BLU CIVIC's Avatar
Track Advocate
talk to your tuner
Old Dec 1, 2011 | 06:06 PM
crvtectim's Avatar
I'm gonna guess that you will need to run about 20-30 lbs. of boost to hit 400whp.
Old Dec 2, 2011 | 02:40 AM
talk to your tuner
tuner Very very Good
I just want to know information
Old Dec 2, 2011 | 02:41 AM
Thank you
Old Dec 2, 2011 | 03:37 AM
crvtectim's Avatar
Since you have the PWM solenoid and neptune with boost by gear capabilities, you could run a 10-12lb. spring in the wastegate and up the boost from there. It would help with traction in 1st and 2nd gear.
Old Dec 2, 2011 | 08:16 AM
Glove's Avatar
hahahahahahahhaahaha
Old Dec 2, 2011 | 09:32 AM
rich7777's Avatar
^^^ x2... How funny...
Old Dec 2, 2011 | 11:58 AM
ThePunisherPnc's Avatar
wow this thread is useless...smfh
Old Dec 2, 2011 | 01:55 PM
DeeC2's Avatar
10 Year Member
17 will do it well at least 4 me
B16Civic93
Jul 13, 2005 02:12 PM
evilk
May 25, 2005 06:39 PM
fullthrottle35
Sep 21, 2004 08:29 PM
Spooled1.6L
Feb 4, 2004 05:40 AM
ramz7887
Apr 29, 2003 09:34 AM
