climate settings wont change
Old Nov 30, 2011 | 05:56 PM
civisedan's Avatar
Default climate settings wont change
Hi I was wondering if anyone knows how I can fix my climate settings so I can change it to the front windshield defrost. Currently it only blows air out of the vents even if I change it to any other setting it won't change.
If anyone has any info that would be great, thanks
Old Nov 30, 2011 | 06:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: climate settings wont change
MM&Y of car would help.
I will assume 91 Honda Civic, so the first thing I would check is the mode control motor, [push button mode control] or air mix cable on left side of heater box, can be seen from under drivers side of dash.
Or if equipped the mode control cable, [lever type mode control] normally on the right side of heater box, probably will have to remove glove box to see it.
Either way, mode control is a number of levers/arms/cams/lingage rods all connected together, with either a cable or motor attatched to one "end" of it, it is pretty easy to see what is wrong. 94
Old Nov 30, 2011 | 06:51 PM
civisedan's Avatar
I'M sorry I forgot to add that it is a 92 integra ls sedan.
Old Dec 1, 2011 | 05:49 AM
fcm's Avatar
fcm
Old Fart
Mode control motor, left side of heater box. 94
Old Dec 1, 2011 | 04:02 PM
civisedan's Avatar
alright is there a fuse that could be possiby blown that is making it not work?
or is there way to test it so i would know if that is what needs replaced?
thanks for the help btw
Old Dec 1, 2011 | 04:50 PM
fcm's Avatar
fcm
Old Fart
Fuse 17 - 7.5A, [hot in run] in under dash fuse box is power for mode control motor, [black/yellow at the mode control motor].
Do the mode buttons light up when you press them?
If not check the ground, same one as the black at the mode control motor. 94
Old Dec 1, 2011 | 05:14 PM
civisedan's Avatar
yes the mode button lights do light up when i try and switch them. they just dont switch.
it doesnt make any noise either like its trying to switch modes.
Im going to check out that fuse tonight and let you know what i find out. hopefully that is all it is. thanks
Reids Del Sol
Nov 13, 2017 01:12 PM
blkegcoupe
Aug 26, 2008 05:01 PM
0ptimus prime
Mar 30, 2004 06:23 PM
PSU
Jul 24, 2003 12:25 PM
eric712
Jun 9, 2002 07:20 PM
