ep3 and rsx question
will coilovers from an rsx fit in an ep3 ?
and the exhaust set up is it the same ??
my friend blew up his base model rsx so i figured i could take his coilovers that are new and his exhaust if it will fit properly
thank you
thank you
if you are getting the coilovers from the rsx, it would be a good idea to get inverted tie rod ends to help with the terrible lack of toe adjustment as well as the angle of the tie rods.
in regards to the exhaust, if it's just the stock exhaust, don't bother since it's a base RSX. However, in general, if you wanted to use a type S header, you will need the type S midpipe as well, and then it will bolt on to whatever EP3 specific axle back exhaust you have.
partsman24
Honda Civic (2001 - 2005)
Jul 31, 2008 03:08 PM
