98 civic EX Tranny
Old Nov 27, 2011 | 05:00 PM
Dinglekidd's Avatar
Icon2 98 civic EX Tranny
Hey im flushing out my Tranny fluid in 4 days. i see that i have to use ATF. but besides that can i get some advice on doing this? i really dont wanna mess up my car. Plus does my model have a filter for the transmission fluid?
Old Nov 27, 2011 | 05:32 PM
furious94ls's Avatar
Default Re: 98 civic EX Tranny
Do you mean the 3x3 change? If so you need 9 quarts of HONDA tranny fluid. Drain, fill, drive for a few miles to get the fluid mixing, then repeat 2 more times.
Old Nov 27, 2011 | 05:33 PM
Ohh, and the filter is internal, just clean off the magnetic drain plug well.
Old Nov 28, 2011 | 07:26 AM
Dinglekidd's Avatar
Sorry but im new to working on cars. I got into it about a year and a half ago, but what do you mean by 3X3? And the HONDA guy said drain the fluid, then put 3 quarts and let it idle for a while, drain it again. Fill it up then im good. That sound about right to you?
I relly appreciate you help
Old Nov 30, 2011 | 12:20 PM
3x3 drain and fill. Do the process 3 times for a 9 quart replacement. Drive the car for a bit, don't just let it idle...
Old Nov 30, 2011 | 06:07 PM
apexi_rsx's Avatar
you can also disconnect the 2 hoses going to the radiator put them into a bucket with the car on jack stands put the car in drive and hold the brake. u can have some one add fluid while it drains or pump a quart out stop,refill,repeat over and over until the fluid being pumped out is brand new red atf color. i recommend using honda atf from the dealer only. this is the only way to properly flush it all out. these transmissions dont have a filter to change so fluid needs to be in tip top shape and changed every 80-100k.
quiet4no1
Apr 2, 2009 10:59 AM
88CRX-CRB-UT
Apr 13, 2007 09:51 AM
eauto
Oct 18, 2004 06:36 PM
return_2020
Jul 7, 2004 08:06 AM
spencedogg
Jun 1, 2003 06:23 PM
