Hard Shutter and Shaking on Hard Braking !!!
Old Oct 7, 2002 | 11:21 AM
TsunamiZC's Avatar
Default Hard Shutter and Shaking on Hard Braking !!!
i think my Rotors are toast ....i was coming off this long toll bridge ....opened up the Type R a bit ....to about 130 mph ....and then started braking .....then i started getting this shaking coming from the steering wheel ...and the pedal got hard ...and was gettiing harder to slow the car down ....
i'm guessing my Rotors are gone .....
i should only need to replace the fronts ....right ...
there seems to be plenty of pad life left ....can i leave the stock pads on ?
Old Oct 7, 2002 | 11:59 AM
TsunamiZC's Avatar
Default Re: Hard Shutter and Shaking on Hard Braking !!! (tsunami_zc)
ttt....
Old Oct 7, 2002 | 12:02 PM
B2FiNiTY's Avatar
Get new rotors. NO biggie.
HybridGSR1's Avatar
yeah ur rotors are most likely warped, changing the front should fix the problem..
Old Oct 7, 2002 | 12:05 PM
TsunamiZC's Avatar
Default Re: Hard Shutter and Shaking on Hard Braking !!! (HybridGSR1)
but can i keep the same brake pads since they have plenty of life left on them
Old Oct 7, 2002 | 12:17 PM
rs's Avatar
rs
keep the pads - replace the rotors with autozone or get them turned. get 4 new rotor screws from acura. the rotors are not "warped" the surface is just not nice and flat/smooth. you can feel this with your finger. you can have the rotors turned if never had that done before and you don't track your car (meaning they are probably too thin and not worth turning). turning is about $10 each and you will still need 4 new screws (if you reuse the ones you have the screw head is likely to break off).
Editted my suck a$$ grammer
[Modified by rs, 1:18 PM 10/7/2002]
Old Oct 7, 2002 | 12:26 PM
TsunamiZC's Avatar
Default Re: Hard Shutter and Shaking on Hard Braking !!! (rs)
koo..thanks
Old Oct 7, 2002 | 12:54 PM
00MRSi's Avatar
I was gonna say what RS said.
Tsunami, not to get off the subject, but who is that hot Piece of *** in your avatar??
Old Oct 7, 2002 | 12:57 PM
TsunamiZC's Avatar
Default Re: Hard Shutter and Shaking on Hard Braking !!! (00MRSi)
Tila Ngyuen http://www.tilashotspot.com (not work safe) and http://www.irevmodels.com (work safe) enjoy
Old Oct 7, 2002 | 01:31 PM
00MRSi's Avatar
Thanks Tsunami.. She is smokin..
Old Oct 7, 2002 | 01:40 PM
AssPenny's Avatar
Put anti seize on thouse little screws (the 2 holder the rotor on) and you'll never have to buy any more again. And just hand tighten them, they aren't going any where. And if all else fails, you really don't even need to run thouse screws. All they do is keep the rotor from falling off when you change the tire
sony224422
Aug 13, 2006 04:30 PM
nikolai.
Nov 23, 2003 05:28 PM
PetroGuyX
Jun 26, 2003 02:10 PM
1337 Si
Nov 25, 2002 05:51 AM
illusion
Apr 10, 2002 09:31 AM
