Is this H22A Turbo return line ok?(PICS)
Do you guys think this is draning properly? I bought a Turbowirx scavage pump because I thought my turbo might have failed becase the oil wasnt draining properly but here is a shot of what the drain looked like before I shipped the turbo back to precision. what you think?
looks like the drain flange of the turbo is below the oil level in the oil pan... That isnt good.
But dont H-series engine sit tilted a bit?
Yeah the flange is sitting below where the block meets the pan. it does tilt a little bit but not enough I don't think..
I can only run 3 1/4 quarts in the pan with the car off before it srarts coming out of the hole... it is sitting low but that's the only place I could weld it with the location of the turbo... so that's why I bought the Turbowrix scavenging pump I think that is my only option with this turbo manifold..
yeah they attach to the drain plug on the pan if im not mistaken?
It probably would work but its not ideal, what you wanna do is clock the center section a little bit so the oil return line points more towards the engine . I'd also retap the pan a little bit higher, also just a little tip to keep in mind, if you have an issue with the return line being so short that it wants to kink near the fittings, used barb fittings, they will prevent the kink. We know all about h22 drain line setups here, done a ton of h22 setups where the turbo sits low.
As for how its setup now, if you look at some of the newer car setups, the return line bung on the pan is almost near the bottom.
