honda civic starting problem.. help
Old Nov 26, 2011 | 12:58 PM
EracerUgone's Avatar
Default honda civic starting problem.. help
Hi. I got a 1993 honda civic ex with a b18c1 (Gsr) in it.it was running fine up until a couple days ago. Everything started up fine and then it just wouldn't start. It starts when I push start it. Right now it doesn't make that clicking noise from the starter, so im kinda lost. If anyone can give me some advise that would be nice.
Old Nov 26, 2011 | 01:03 PM
grumblemarc's Avatar
The Grumpiest
Default Re: honda civic starting problem.. help
Sounds like the starter to me.
Old Nov 26, 2011 | 01:12 PM
Alright. Ill give it a try and will get back to this
Old Nov 26, 2011 | 03:23 PM
apexi_rsx's Avatar
first check your motor grounds and make sure they all have good contact. a weak contact or corroded ground will not turn over the starter and it will just click.
Old Nov 28, 2011 | 02:59 PM
I tried all that, but it doesnt start. When i turn the key to try and start it, it doesn't make the clicking noise like it normally do. I changed the starter out to a different but it does the same thing. I changed the main relay but still does the same. Any info on where the "starter relay" is? or how to jump it from the starter?
Old Nov 28, 2011 | 04:02 PM
Former User's Avatar
Check whether the rubber stopper fell out:
Jack Murphy
Jun 21, 2017 06:23 PM
norbertocartage
Feb 25, 2013 07:30 AM
Tunerguy1989
Nov 16, 2009 03:52 PM
civicbro
Feb 19, 2004 02:47 AM
Goy091
Jul 7, 2002 06:09 AM
