My Civic starts without pressing the clutch, how can I fix it back?
Old Nov 26, 2011 | 12:02 PM
JaimmyACA's Avatar
Default My Civic starts without pressing the clutch, how can I fix it back?
Hello, just wondering why my Civic starts without the clutch, as to original ones start by pressing the clutch? What do i need to connect?
Old Nov 26, 2011 | 12:03 PM
B16bcivicsi's Avatar
Default Re: My Civic starts without pressing the clutch, how can I fix it back?
Clutch switch
Old Nov 26, 2011 | 12:10 PM
DPancoast's Avatar
+1 on the clutch switch. Look under the dash in the clutch pedal area to see if there is a paper clip or wire jumping the switch and making it so you don't need to push the clutch in. That's usually how people ghetto bypass it.
Old Nov 26, 2011 | 03:27 PM
apexi_rsx's Avatar
was this an auto to manual swapped car? you may have to look it over and wire in your clutch switch. mine does not require the clutch to be engaged because mine was a auto to 5 speed swapped car and i never hooked up the clutch switch.
Old May 26, 2013 | 06:24 PM
ambergilbert00's Avatar
Originally Posted by B16bcivicsi
Clutch switch
I was wondering if my 94 is actually supposed to turn over without the clutch down? I have been have trouble starting my car in the heat for some reason and I don't know what wrong with it. I was trying to start it today and I did it without the clutch down just to see what would happen and it tried to turn over I also noticed that a can change gears with out it down.
any ideas????
Steven Gilner
Sep 26, 2013 10:20 PM
96H4TCH
Jun 22, 2009 11:19 AM
zc89hatch
Feb 2, 2008 09:05 AM
TEGPOWER44
Dec 16, 2002 10:11 AM
3rdGteg
Nov 14, 2002 07:43 PM
