temperature problems
today my car was overheating and found out that a hose underneath the intake manifold..a hose was not clamped on tight enough and antifreeze was leaking so i went to auto zone to get a new peaice of hose with clamps and antifreeze and when i installed it and put in new anti freeze.. now my temperature gauge stays at cold unless im at a stop then goes up a little and when im driving it goes back down to cold?? any suggestions and is it something to be worried about??
replace the thermostat i had this problem when u rev the motor it pushes coolant past the lil O-ring that stops the coolant from entering the block until its open. Replace the thermostat and im sure this problem will go away.
K7-1Ktrevor
Jan 11, 2010 06:03 PM
blinger
May 14, 2007 06:39 PM
tFUnK
Jan 2, 2003 12:56 AM
