Where to aim the timing light
Old Nov 23, 2011 | 11:50 AM
90civic-ZC's Avatar
Default Where to aim the timing light
Ok, I dont wanna sound like a idiot but I've never used a timing light before. In the discription in the book it says to just aim it at the crank pulley or bell housing depending on where the timing marks are. Do I need to take my timing belt cover off to expose the actual arrow and crank gear or do I just aim it at the crank pulley? It's a DOHC ZC.
Old Nov 23, 2011 | 12:32 PM
///Mathew's Avatar
Default Re: Where to aim the timing light
No, the cover stays on. You should be able to see the marks on the outer crank pulley.
Old Nov 23, 2011 | 01:58 PM
JDpower's Avatar
Just pos/neg, number one cylinder spark plug. Aim at the crank and adjust dizzy till dead on the red mark(should be 16 or 18 BTDC i forget)
Old Nov 23, 2011 | 02:04 PM
90civic-ZC's Avatar
Alright, easy enough.....thanks a bunch guys!
Old Nov 23, 2011 | 02:14 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just so you know there is a tab on the timing cover itself that you line up the middle mark out of the 3 timing marks. The one off to the side is for TDC, which can also be found without removing the timing cover.
Old Nov 23, 2011 | 02:36 PM
90civic-ZC's Avatar
Ah yes, I know what you're refering to. Thank you
londoncrx
Mar 6, 2011 06:30 PM
ToTriggerHappy
Jan 13, 2011 06:31 AM
Civic-Kids
Mar 12, 2009 01:45 PM
ApolloSpeed
May 1, 2005 08:31 AM
wantmorepower
Apr 15, 2003 08:07 PM
