A total noob question.....about timing
After My b16 starting bogging and running bad..... and black stuff running out the pipes.
I wanna check my timing,
So.
The #1 plug wire is the bottom left (looking at the dizzy)
then I start the motor, and point the light where ? The crank pulley ?
So.
No Sales Forums
Re: A total noob question.....about timing (ApolloSpeed)
Yes the timing marks are on the crank pulley, there is also another (pointer) on the plastic timing belt cover (you will need). Those motors generaly run well at 17 degrees advance. I would set it there.
no, you just need to know what you are looking for. there are marks on the pulley (one is pink if i remember right) and there is a solid line that is raised on the timing belt cover. point from the back of the car down at the pulley
NSfit
11-26-2006 07:34 PM
wantmorepower
04-15-2003 08:07 PM
