what to drop in EK or EG?
Old Oct 7, 2002 | 09:44 AM
BuRcH's Avatar
Default what to drop in EK or EG?
hey i juss wanted to know if the only real differences in dropping a b18c1 in a ek and dropping it in a eg was only style. thanks in advance for yoor comments
Old Oct 7, 2002 | 10:22 AM
The G2 Racer's Avatar
Default Re: what to drop in EK or EG? (E K)
EGs are lighter then EKs
Old Oct 7, 2002 | 10:24 AM
NonovUrbizniz's Avatar
Loved
Default Re: what to drop in EK or EG? (The G2 Racer)
the rear (and maybe front) suspensions are different. the ek ex's come with rear disk where eg's it was a seldom taken advantage of option.
Old Oct 7, 2002 | 10:28 AM
KEVlN's Avatar
New User
Default Re: what to drop in EK or EG? (NonovUrbizniz)
Go with the eg. Looks better IMO.
-kev
Old Oct 7, 2002 | 10:34 AM
Plan B's Avatar
The rear uses different LCA's that are shorter, that's about it as far as suspension differences. The Front has a different shaped upper control arm, but it's very similar, just bolts up differently.
The shock forks are different.
I don't think i've ever seen an 96-00 ek with factory rear disc, only the Si's. The 94 and 95 ex's were available in an EX-A trim level, which had 4 wheel disc brakes with ABS. The 92-95 si hatch also came with disc brakes. I don't think any Ek's were available with rear disc until 99 with the Si.
The engine bays are different on the two cars. In the EK, you will have to get a lot of mounts and brackets and such from an Si to make the swap work. The EG is much more simple. Only requires a different rear bracket and A/C bracket than that of the civic. Also, throttle cable, a few other minor things.
Correct me if i'm wrong, i'm all about not spreading misinfo.
Old Oct 7, 2002 | 11:13 AM
BuRcH's Avatar
Default Re: what to drop in EK or EG? (Plan B)
thanks alot for the comments guys`is it really that much more to swap into a EK tho? i really appreciate yoor help thanks again
Old Oct 7, 2002 | 11:23 AM
TheIntegraGuy's Avatar
Swap it yourself..it's cheaper and you learn alot more about your car that way....EG's my choice of car...B18CR is my choice of motor..
Scooter426
Jul 3, 2011 10:08 PM
1 jonesie
May 20, 2007 05:08 PM
KillBot
Mar 12, 2005 10:56 AM
endlesswinterco
12
Nov 7, 2003 05:43 AM
ATS*Mark
15
Mar 16, 2003 12:31 PM
