Engine knock, or rough idle???
Old Nov 23, 2011 | 06:27 AM
01PhoenixITR's Avatar
Icon2 Engine knock, or rough idle???
I came into ownership of my b-e-a-utiful Phoenix Yellow 01 ITR (#1112) this past september, i took it to my local Honda dealer to get it all checked out and somehow they seperated the oil dip stick support tube from the block and some oil drained out and shot all over the inside of my engine bay, after taking it back and raising some hell they replaced some of the oil and said i should be good to go, ever since then its run a little ruff and idled a bit high 1100-1300RPM and the Maintenence Reqd light came on and I'm kinda lost on what to do, i've already called the dealer for them to take a look at it again but i'm not a trusting person of this dealership. Any advice, tips or things to check, maybe i'm just being paranoid....
Old Nov 23, 2011 | 12:19 PM
motegicivic's Avatar
Default Re: Engine knock, or rough idle???
I think the tube is a pressure fit, but I am not sure?
As for the maint light that is like any honda, just tells you when you are due for an an oil change.
What is the mileage of the car?
I would get an oil change and do a tune up, cap rotor, wires and plugs and see how it runs.
Old Nov 23, 2011 | 01:00 PM
Its got 78xxx on it, and i got an oil change right before it all started happening. :/ Royal Purple!!!
Old Nov 23, 2011 | 01:49 PM
Then reset the maint reminder.
Old Nov 28, 2011 | 05:10 AM
After googleing a bit, I really didnt find a clear answer on how you reset the light.
Care to explain an easy way to do that?
Old Nov 28, 2011 | 05:41 AM
Rene1123's Avatar
under the steering column to the right side you should be able to feel it with your hands
Old Nov 28, 2011 | 09:56 AM
http://www.team-integra.net/forum/bl...nce-light.html
Old Nov 28, 2011 | 02:30 PM
FULLYBUILT2.0's Avatar
X2...
mraza
Aug 1, 2006 11:24 PM
KFBhonda
12
Oct 12, 2005 01:30 PM
JDMF22B
Jun 10, 2005 10:00 AM
jdmhatch94
Jul 18, 2002 03:40 AM
