B16a vtec help.
That helps a little bit but I don't know what wires on the engine are Spose to go to that spot inthe ecu
Yeah where that bolt is you'll need to get a pressure switch from the junkyard, Honda or online somewhere. Any pressure switch 88-01 Honda or Acura will work.
k thanks. so that greenwire and red wire below the solenoid isnt the pressure switch I think it might be that because it's a b16a out of a 92 integra migh be wrong so confused got the wrong Haynes repair manual
http://i1218.photobucket.com/albums/...ncrx/photo.jpg
so is the hole to the left where the pressuer switch is spose to go becose its just an empty hole
I hate being such a noob!! at this lol but I cannot start my own thead yet so hopefully I will get some replies here I am swapping a b16a (obd0) into my 93 ex coupe. Im in no hurry to get it in b/c the z6 in it is running fine and I want to do it right. as far as ecu and wiring what kind of issues am I going to run into when it comes to dropping it in. I will be doing an all motor build on the b16 before swapping and any help with that would be greatly appreciated as well.
xtreme-customz
Nov 10, 2005 03:20 PM
