Possible to disable TPNS sensor?
Old Nov 21, 2011 | 07:30 PM
Baffle's Avatar
Default Possible to disable TPNS sensor?
(Sorry title should be TPMS, missed my typo before i posted...)
Just curious, because I bought my 2008 Civic lx used and I've put about 1500kms on my swapped winter rims (no sensors) and I have no light in the dash.
Also when I turn on the headlights I am used to having the shifter positions light up (yes it's an automatic) and that illumination is not present either like it was in my 01 civic dx model.
Not sure if someone might have disabled the light in the cluster before i purchased it is all. Not a big deal, car is in excellent shape otherwise.
When I turn the key to first position and all the lights come on in the dash (test) there is no tpms light either. I have never had a car with tpms before so not sure what the light should look like.
Any opinions would be welcomed.
Old Nov 26, 2011 | 06:36 PM
Baffle's Avatar
Default Re: Possible to disable TPNS sensor?
I think i got everybody stumped...
Old Nov 26, 2011 | 10:54 PM
randomtask77's Avatar
Have you tried pressing the "+" button on your dash that turns up the brightness of the illumination of your gauge cluster?
Old Nov 27, 2011 | 05:24 AM
CRX-Kid11's Avatar
the light should come on no matter what for a couple seconds once key is turned on, i believe it was mandated that all 08+ cars need to be equiped with tpms, sounds like some one removed bulb in cluster
Old Nov 29, 2011 | 12:39 PM
doc@tirerack's Avatar
Yep, short of disconnecting the bulb or putting tape over it we are not aware of anyway to turn the system off.....
Old Dec 1, 2011 | 05:33 PM
Baffle's Avatar
Ok so it may be a bulb issue, in a digital cluster though?
The illumination is not an issue, and I whacked the shifter the other morning with my lights on and now the <P-D-D3-2-1-N-R> is illuminated as it should be. Just a loose connection in there perhaps.
I'll get the mechanic to check my cluster bulbs next time it's in for service.
Thanks for the responses.
moss500
May 8, 2014 06:09 PM
chatman_55
Mar 14, 2008 02:54 PM
rleonekc
Mar 30, 2006 11:14 PM
ebelp
Acura TL, RL & ZDX
Aug 1, 2004 08:34 AM
