Numerous check engine codes
If you loved me, you'd all sell me your magic cards to me today
96 cx with a JDM B16A swap and was running obd1 p28
I have now swapped in a p2t with a jumper for obd2a so it plugs right in.
I am getting these codes
P1259 - Vtec, I know that I need to wire it out of the p28 and back into the stock harness. Easily done I can find the diagram of which pin is for which wire.
P0135 - O2 primary sensor. I have a JDM header and did not see a bung to wire one into? Is this correct? Where would it normally wire into? My car is going to the shop to get a cat wired in anyways so a bung could be added, I just do not know where.
P1337 - LEET. ok kidding CKP sensor, if I remember this is common on this swap and there are howtos about it
P0141 - O2 secondary. I have a cat I ordered for the 98 EX, it has a bung half way through the cat, is this for the primary or secondary? if it is the primary does the secondary go after the cat then?
P0450 - FPS. Again there are write ups on this, I am sure I can handle it.
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
not tryin to be a jerk, just clarifying.
the primary goes before the cat.
secondary goes in the cat.
Unless one of those other codes is not at all what I think it is then yes O2 sensors. Any idea on the bung on the stock b16 header? I may have to go look again. Where does the wiring from the O2 goes after the O2 so I can check.
j.orr
Mar 25, 2009 09:25 PM
