95 honda del sol vtec
Old Nov 21, 2011 | 11:18 AM
big b280's Avatar
Icon2 95 honda del sol vtec
My del sol's check engine light came on after driving for 45 min, kept running fine. When i turned it off, the light went off. It did it 2-3 more times. Now it started sputtering in all geers. When the rpms r high it runs better, but it has a constant sputter. I thought it may b an 02 senser, but i am not sure. Nobody can read the codes before 96,
that i have asked. Can anyone help?
Old Nov 21, 2011 | 11:39 AM
crx_si-r's Avatar
Default Re: 95 honda del sol vtec
There is a small blue 2 wire plug located on the passenger side kick panel. Take a small wire or paper clip and make a jumper. Your check engine light will then flash. Count those flashed then report back. We can tell u what they mean.
1 long flash means 10
1 short flash mean 1
Ex.
Long flash, short flash, short flash means 12
Old Nov 21, 2011 | 11:45 AM
JDM-Punk's Avatar
Ex.
what this guy said^
Old Nov 22, 2011 | 02:18 PM
big b280's Avatar
Thanks for responding! The code came up as 43. I chrcked it a couple of times and that is the only code that appeared
Old Nov 22, 2011 | 02:38 PM
big b280's Avatar
Old Nov 22, 2011 | 03:34 PM
grumblemarc's Avatar
The Grumpiest
Check the stickies at the top of the forum. There's one that addresses how to check codes and what they mean.
Elijah Herndon
May 22, 2017 03:16 PM
lgoodgrace
Apr 27, 2015 03:43 PM
k.0.0.l.
Jan 6, 2013 10:15 AM
Guitarzann
Dec 13, 2005 10:21 AM
KillaBk
Oct 29, 2005 06:00 PM
