B16A2 Coolant Problem!!!!
Old Nov 21, 2011 | 05:01 AM
jap305's Avatar
Icon3 B16A2 Coolant Problem!!!!
Need help asap!!!
So i have a coolant problem idk whats happening but i need i diagnosis quick. So my overflow bottle is losing coolant fast, there is coolant on the top of the radiator and some how on the air box. i popped the hood and the coolant on the top was burning off. my temp gauge stay in the center and the car doesnt bog or anything. im not driving hard and its still doing this ****. people are saying water pump and some hose in the back of the block. i think its either the radiator itself or maybe just the cap is gone. i need any kind of input. thanks
Old Nov 21, 2011 | 05:53 AM
grumblemarc's Avatar
The Grumpiest
Default Re: B16A2 Coolant Problem!!!!
Sounds like you have a leak somewhere. Check teh plastic top of the radiator where it meets the folded over metal. It's common for these to start to separate and sometimes it's hard to spot leaks.
Old Nov 21, 2011 | 07:43 AM
jap305's Avatar
Yeah ill check is there a way to fix that or do i need a new radiator
Old Nov 21, 2011 | 07:46 AM
The Grumpiest
Can't be fixed. If that is the problem.
Old Nov 21, 2011 | 07:49 AM
jap305's Avatar
Alright new radiator it is. Thanks
Old Nov 21, 2011 | 08:26 AM
newem1er's Avatar
clean the area around the radiator and then refill and check for the aboslute spot of leakage .my friends 95 dx radiator just cracked at the plastic and he was eating up fluid and leaking ..new radiator and no leaks now.ebay radiator ...
Old Nov 21, 2011 | 09:52 AM
jap305's Avatar
thanks im def gunna check that plastic part eventhough i think its a little more than just that but i just need to be able to run it without over heating. thanks guys
ShotnVA777
Jan 9, 2014 04:13 AM
Sl0wH0nda
Jun 13, 2013 10:22 AM
poorman's type-r
Oct 29, 2006 09:18 PM
Tim.
17
Jan 30, 2006 09:17 PM
The-LS
Jul 14, 2004 01:16 PM
