Droning Noise 93 EX Coupe
I am experiancing a noise similar to this.
http://soundbible.com/grab.php?id=1305&type=mp3
It occurs over 25 miles and doesnt disappear when I push in the clutch. I replaced the tie rod ends, wheel bearings and axles about a year ago and thats when the noise appeared. Tires have been rotated 2 or 3 times and noise continues to persist.
Was not aware it needed to be greased as its supposed to be a sealed unit? They were NAPA branded bearings, and wouldnt it be makign noise at all speeds?
That would suck then, is there a way to confirm that it really is the bearings? There's no loose feeling or anything like that and last time I had the tires rotated the guys who did it didnt note any problems with the bearings like they had in the past (I had an inch of slop on both sides indicated both needed replaced after 17 years of service and thats when the bearings, the tie rods (i and o) and the drive shafts were all replaced. (All the rubber had died) Plus the noise only starts ove5 25-30mph
kenskii
Jul 8, 2014 08:33 PM
