FINALLY solved skunk2 manifold probs..pics..
Old Oct 7, 2002 | 05:35 AM
SuperCivic's Avatar
Default FINALLY solved skunk2 manifold probs..pics..
yeah, mystery solved. turns out the throttle body gasket that manchester honda sent me was for a 97-98 b20b, whereas my b20z throttle body was from a 99-00. THIS was the cause of my miraculous vacuum leak, not the skunk2 manifold, not the manifold gasket. impressions are...definately feels like it's breathing better all through the power band. it's actually worthwhile to rev up to redline now..it pulls strong all the way up, rather than falling on it's face after 6k. i'll find out the real improvements when i take it back to the little 1/8 track this thursday. here's some pics of the installed mani..enjoy.
Old Oct 7, 2002 | 05:39 AM
EP3_05's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (SuperCivic)
Nice job on the install...glad to hear that you fixed the problem. Did you have any clearance issues with the fpr and the throttle cable and bracket?
Old Oct 7, 2002 | 05:46 AM
SuperCivic's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (91civic)
i happened to have a FPR that had the bend in it..i had to bend it a little more to make it work..the throttle cable bracket is only held on by one bolt, but it lines up well, and no real clearance issues. it's tight in there, but it works.
Old Oct 7, 2002 | 06:22 AM
xtrafastcivic's Avatar
john - who's waiting to hear the 1/4 err 1/8 mile times...
Superhatch's Avatar
Yummy
Old Oct 7, 2002 | 06:24 AM
keithv's Avatar
a friend of mine will be dynoing his b20b /skunk2 IM in 2 weeks. he dynoed the b20b w/LS IM a month ago. this session will include tuning, so he hopes to get some good numbers. i'm sure he will chime in here soon.
Old Oct 7, 2002 | 06:25 AM
EF_LSVtec's Avatar
good to hear...i'm closely waiting for your post because i have a skunk2 manifold too that I will have to install in a couple of weeks...
Old Oct 7, 2002 | 07:54 AM
SuperCivic's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (EF_LSVtec)
it's not too hard, just ask if you can't figure something out.
i can't wait to run it...i'm really bad at drag racing, but at least then i'll know how much an improvement is made.
Old Oct 7, 2002 | 09:35 AM
Charlie Moua's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (Home audio video man)
Glad to see that everthing is working out great. get some cams bro then that thing will really be breathing better. 62403 or 62404.
Old Oct 7, 2002 | 09:40 AM
SuperCivic's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (Charlie)
i really want a jdm4-1 w/ a thermal exhaust first..just running stock b16 header w/ a custom 2.25 right now
Old Oct 7, 2002 | 09:41 AM
EightOhOne's Avatar
Looks good man. i also had to bend the fuel return line on the fpr for it to clear the manifold, and the throttle cable is a little harder to adjust since the fpr is in the way, but nothing too tough
Thanks for your help on my swap. i finally got it running, and just got rid of the codes today....too bad i have to drive like a granny for 500 miles
Old Oct 7, 2002 | 11:40 AM
SuperCivic's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (EightOhOne)
so what do you guys think is a good setting for the fuel pressure regulator?
Old Oct 7, 2002 | 01:38 PM
stock unless you're on a dyno
Old Oct 7, 2002 | 02:53 PM
Tbone's Avatar
So did manchester honda send you the wrong gasket or did you order the wrong one? I'll go over there for ya and bonk them all on the head, I know most of the people there.
Old Oct 7, 2002 | 03:12 PM
E-lude78's Avatar
whats better for N/A , SKunk2 or JG/Edelbrock intake manifold?
Old Oct 7, 2002 | 03:46 PM
Tbone's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (Mista B-one-seven)
From the dyno plot I saw , jg lost power all the way till up top where then it began to finally see some gains..We might throw one on my motor after its all tunned with my todas, or hondasaver cams.(whichever do best) just to see how well it does up against my ported skunk manifold.
Old Oct 7, 2002 | 06:56 PM
getnasty's Avatar
hey i think i know who you are. did nate put that b20 in your hatch. and your friends with champ and sprinkle. if thats you i was up at sonneys when you and champ came up there
Old Oct 8, 2002 | 02:05 AM
carsaregood's Avatar
i love mr. bungle too. mike patton
Old Oct 8, 2002 | 03:54 AM
SuperCivic's Avatar
Default Re: FINALLY solved skunk2 manifold probs..pics.. (bottle fed)
when i talked to jeff at manchester, i just ordered the b20 throttlebody gasket. i had no idea the 97-98 gasket was different than the 99-00 gasket, but after we figured out it was the tb gasket i was pretty sure that's what happened. it would have saved me a hundred bucks labor if jeff had said, "is that for a 97-98 or a 99-00. i had my old b20 tb gasket laying around, so i installed it and the prob was fixed. to make it up to me jeff is sending me a 99-00 tb gasket. yay. please give him a good bonking.
yup, that's me. my car was up at nate's shop for a few weeks..he installed the motor at no charge.
Mike Patton is cool. Tomahawk FNM Bungle fantomas
johan60
May 6, 2016 01:08 PM
crazihobo
Jan 29, 2012 09:41 PM
