stock ls on 18psi with no tune wtf?
no tune no boost right? wtf is this guy really tryna say an "Ls can handle 18 lbs of boost with a check valve fmu and no tune done it already no problem whatsoever." bullshit right?
FMU is a rising rate fuel pressure increaser.his fuel psi at 18psi of boost would be ridicoulos.litteraly washing oil out the cylinder walls.
Assuming he has a fuel pump that can handle the additional pressure and keep up with the flow demand, 18psi without addressing the standard timing will make for a quick life.
spooledhonda
Jan 3, 2006 03:23 PM
JM Performance
Nov 28, 2001 03:46 PM
