ls bogs at boost
Old Feb 10, 2004 | 08:44 PM
totalimpact's Avatar
Default ls bogs at boost
My buddy just put a rev hard kit with FMU on his LS set @ 8lb. When it hits boost its like the ECU cuts spark. No CEL. Hes tried the missing link and has a vafc, and cant get it to run right. I thought it was the MAP sensor, but theres no cel.
I know i have seen this post before, but couldnt find it.
Old Feb 10, 2004 | 09:13 PM
Rod.'s Avatar
Default Re: ls bogs at boost (totalimpact)
take it to a dyno and get it tuned
Old Feb 10, 2004 | 09:55 PM
b18b1hmtlove's Avatar
What are his settings with the AFC? please post the injectors and all that good stuff. At minimal if hes rocking 450's he should have 35 across the board.....
450's w/ an AFC you can run like 39 or 40 up to where the turbo starts to spool. so like 3000-35000 rpm and then i would do like 37 and make sure by the time you hit full boost you are at about 35
oh, all these values are in the negative obviously
Old Feb 16, 2004 | 09:24 AM
Default Re: (b18b1hmtlove)
Injectors are stock, the FMU controls a high pressure fuel pump that is supposed to increase 7-8 lb fuel pressure for every lb of boost.
Old Feb 16, 2004 | 09:35 AM
turbo craig's Avatar
Default Re: (totalimpact)
he needs a 12:1 fmu 12 lbs of pressure for each lb of boost..umm i think he may be detonating
Old Feb 16, 2004 | 10:39 AM
Deluzional's Avatar
Default Re: (turbo craig)
From what i always hear, never run any afc with fmu, missinglink, check valves. Before when i ran the afc without the hack, i used a check valve too. Car ran fine cept it wouldnt let me push it past 4k. Then i ditched the check valve and now the car runs great. trust the hack
Old Feb 16, 2004 | 01:41 PM
Ya, i had him double check the settings he has, and it is 12lb.
Old Feb 16, 2004 | 01:44 PM
DEVIN22CBR's Avatar
Is your inline/intank hooked up backwards ?
EF8DayDreamer
Nov 20, 2011 05:57 PM
ismkv8s
Mar 13, 2003 08:24 PM
JeremyL
Dec 9, 2002 05:56 AM
SlowB16
Aug 3, 2002 10:18 PM
DLB1994
Jun 2, 2002 07:01 PM
