rotor ignition direction
Old Nov 17, 2011 | 07:09 PM
Da9austinRacing's Avatar
Default rotor ignition direction
If my cylinder 1 is tdc which direction should my rotor be facing
Old Nov 18, 2011 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Default Re: rotor ignition direction
It should be facing the #1 spark plug lead, bottom left when looking towards distributor.
Firing order is, [clockwise] 1342, cylinders are 4321 from left to right. 94
Old Nov 18, 2011 | 09:18 AM
TheRealTegger's Avatar
If you're standing at the passenger fender, looking into the engine compartment, the #1 cylinder on the distributor is at BOTTOM LEFT.
With the #1 cylinder at TDC compression, the distributor rotor should be lined up with that bottom-left terminal.
Going CLOCKWISE from the #1 terminal, the next terminal is #3, then next #4, then next #2, and then you're back at #1 again.
Old Nov 18, 2011 | 11:20 AM
fcm's Avatar
fcm
Old Fart
Doh!!! TheRealTegger is correct it is the bottom left, [just like my 94] my Haynes shows it as top left and does not explain the line drawing of distributor is rotated 90 degrees clockwise. 94
Old Nov 18, 2011 | 05:18 PM
Appreciate the info tanx.
Old Nov 18, 2011 | 05:21 PM
Can incorrect ignition timing cause fluctuating idle?
Old Nov 18, 2011 | 05:46 PM
No. That's normally an air leak.
Old Nov 18, 2011 | 05:51 PM
Any common spot to get an air leak because I can't figure out the idle problem
Street_sleeper
Oct 15, 2011 05:47 PM
95civhb
Aug 14, 2010 06:51 AM
azzurribaggio
Jun 26, 2009 09:25 PM
azzurribaggio
Jun 26, 2009 05:07 PM
dlric
Dec 13, 2001 03:55 AM
