b20 swap help!!!!!
Old Nov 17, 2011 | 05:11 PM
2000 EK's Avatar
Icon2 b20 swap help!!!!!
so i have a 2000 civic ex and i want to swap it out with a b20 my engine harness is also chopped up and no good.
what engine harness and ecu can i use? PLEASE HELP!!!!
Old Nov 17, 2011 | 05:14 PM
95EG2's Avatar
Default Re: b20 swap help!!!!!
OBD2 LS ECU AND ENGINE HARNESS
Old Nov 17, 2011 | 05:15 PM
95EG2's Avatar
U can use everything u would use on a LS swap
Old Nov 17, 2011 | 05:21 PM
2000 EK's Avatar
Icon2 Re: b20 swap help!!!!!
does it matter if its obd2a or obd2b
and will it pass inspection in mass.
Old Nov 17, 2011 | 06:51 PM
2000 EK's Avatar
Some please help need this car out asap
Old Nov 17, 2011 | 07:05 PM
95EG2's Avatar
read this... it quicker if u just google it
http://www.b20vtec.com/forums/b-seri...-harnesss.html
Old Nov 17, 2011 | 07:06 PM
95EG2's Avatar
dont know if it pass mass. inspection but in MD swap motor pass inspection
Old Nov 17, 2011 | 07:08 PM
2000 EK's Avatar
been searching but dont really seem to find a straight answer
Old Nov 18, 2011 | 03:47 AM
2000 EK's Avatar
bump this up need help asap
Old Nov 18, 2011 | 07:10 AM
EsotericImage's Avatar
Retired Moderator
u can use another EJ8 harness, but the distrib and a sensor here and there will need to be re-wired. also a ECU harness will need to be used.
Theres also distrib harnesses that are plug and play to save you if your wiring/search challenged.
http://www.velocityshop.com/categori...lated_117.html
Old Nov 18, 2011 | 01:31 PM
Hatemy7's Avatar
i def bookmarking this thread since thats the swap im going with
Old Nov 18, 2011 | 01:52 PM
apexi_rsx's Avatar
use the stock civic harness then buy a crv ecu it should all plug and play. you will have the extra wires to wire a vtec head on if u want to int he future. the crv and your civic harness are identical other then you civic have vtec.
Old Nov 18, 2011 | 02:37 PM
2000 EK's Avatar
thanks for the info
My#1teggy
Honda CR-V & Element
May 22, 2019 02:28 PM
cup cake
Jun 23, 2010 12:26 AM
NBPdEeCeE
Nov 11, 2008 07:07 PM
slo_ej8
Apr 8, 2008 12:36 AM
cas95
Nov 20, 2006 01:12 PM
