innovative wideband troubles
Old Nov 16, 2011 | 04:13 PM
v8killaz's Avatar
Default innovative wideband troubles
trying to figure this out. seems like im getting some weird reading
every ground is run to the thermostat ground. and every wire has been checked.
both analog 1 and 2 set to 0v-7.35 and 5v-22.39 for use with wide band gauge and hondata
hondata is not wired currently
video of analog outputs on the test gauge. my gauge installed in-car is reading weird dont know why
notice analog 1 reads perfect but analog 2 reads lean. i dont know why.
heres a video of my gauge in-car. it reads off while plugged into analog 1 which on the test gauge reads perfect
so is both the lc1 and my gauge screwed up
Old Nov 16, 2011 | 04:56 PM
jdmadam's Avatar
Default Re: innovative wideband troubles
Are you sure that you have both analog 1 and 2 set to 0v-7.35 and 5v-22.39? Where are you pulling power from? Do you have any other electronics in your car also grounded to the thermostat housing?
Old Nov 16, 2011 | 05:20 PM
HAMOTORSPORTS's Avatar
The thermostat ground is noisey/lots of interference. Use a different location...
Old Nov 16, 2011 | 05:42 PM
v8killaz's Avatar
nothing else. everything else is grounded to someplace else
only things i ground the the thermostat are things that are related to engine. like the wideband and gauge.
the problem with the lc1 has been fixed thought i got a used one and plugged it in and recalibrate an works perfect. all numbers match perfect with hondata.
thermostat ground was told to be the best spot for the wideband ground
and problems with lc1 has since been fixed. replaced lc1
checked outputs with the test gauge and they are 100% matching with logwerks.
hoked up to hondata and numbers match 100% hook wideband up to gauge and the numbers are lean. so im going to go ahead and come to the conclusion gauge is ****ed
thankyou both for the help appreciate it
dejay2014
Jul 15, 2015 01:25 PM
maxwellmercer
Oct 20, 2010 01:31 PM
Boostinb20!
Jun 27, 2009 05:52 PM
donkiman
Dec 9, 2004 01:23 PM
