Step Deck Vs O-Rings
Hey guys,
Running a D16z6 block with a D16y8 head. Currently had a few head gasket issues and looking to both re-engineer my setup a little stronger and also go for a more conservative timing values with my tune.
I am wanting to achieve a better headgasket seal.
Currently have Dart Sleeves, Cometic 1.3mm MLS head gasket, 76mm Bore.
Wanted to know the Pro's & Con's of O-rings Vs a step deck and what would be the better path to go down etc or possibly both?
Thanks in advance !
Thanks in advance !
Ivee done step deck worked great I flat my block stepped it .030 the same as my hg with arps never had a problem with gasket never did o ring I heard if not done right could cause sealing issues
Step decks are becoming less poplular. O-ringing is most definatly a better method. Alot of people with Hondas do the copper o-rings (which is what i have) Although some people do use stainless wire with a reciever groove in the head. Ive also heard that some dont use the reciever groove with MLS gasket. I think copper wire is defintaly most common within the honda community tho
But without a doubt i would say 95% of honda builders out there go Sleeve of thier choice with Copper O-rings
